Master cylinder installation
I am switching master cyl and am stuck geting reservior lines back into ports. It has been awhile since I have done this and feel there must be a trick....Remember I have limited space for muscle application (not luxury of lift).
HELP ! Terry
TOT |
914 Geek
Get some brake lubricant paste. Brake fluid will work, but the actual lube is better. Install the tubes into the master cylinder before bolting the MC up if you can. Consider new seals/grommets for the lines going into the MC.
It's not a fun job, any way you do it... ![]() --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Undue the clamp holding the brake reservoir to the bracket, this allows you to lower the lines and the reservoir down a foot or so below the car. Now you have the needed leverage to easily pop them into the master cylinder grommets. Took me about 30 seconds to pop both into place.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Non User
Infraredcalvin - AKA Pat '76 Turbo Carrera #311 - Factory LSD, Sport Seats ‘71 914-6 GT 3.4L twin plug track car '75 914 GT clone project '71 914 track car, fresh 2165 FAT motor (for sale soon) |
master
Ruefer:
IS great suggestion...Actually had gas tank out so it was a piece of cake...leverage is the key and as DD said new rubber which I also did. Thanks all.
TOT |
