how to clean relay board?
Well I dug out of my pile of parts 2 engine relay boards. The epoxy on the bottom is in good shape on both. But both are pretty dirty / grimy from years of being in various boxes and I suppose in cars. So how do you go about cleaning these? How do you clean the female sockets for the relays? Is alcohol a good cleaner to use? Once everything is clean can dielectric grease be applied to the relay pins,harness contacts and the fuse holders?
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
I always found WD40 to be the best way to clean them, that and a couple of tooth brushes should get you on the right track
