Paining the heat exchangers
So.. I removed the heat exchangers on my 74 1.8. I am replacing the push rod tube seals.
I am wondering about painting the exchangers, and was looking for some suggestions as to what kind of paint to use?
Thanks in advance!
Mike
Old 03-16-2009, 09:33 AM
Inschool's Avatar
High temp paint, caliper paint. You must remove all the rust from metal or the paint will not hold. It is very difficult, unless you have a media blaster on hand.
No minivans!
Old 03-16-2009, 05:49 PM
Non User
infraredcalvin's Avatar
I tried painting my muffler with the cheap high temp stuff from the local APS. Watched it fry and flake after about 30 sec of running. I spent a lot of time preping and cleaning... a little p.o. when it flaked that fast.
Infraredcalvin - AKA Pat
'76 Turbo Carrera #311 - Factory LSD, Sport Seats
'75 914 GT clone project
'71 914 track car
Old 03-16-2009, 07:24 PM
Get them ceramic coated. IT will last, even on old metal.
Clay Perrine
74 914 1.8L (Frodrick)
73 914 /6 4.0L 964 motor (Igor)
70 914 /6 Factory Six. (Elwood)
95 BMW 540i (Inga)
Old 03-16-2009, 08:39 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Paint won't last long on the heat exchangers. Ask me how i know. Stainlees Steel HE's or have your's ceramic coated. They will last longer than the car.
Old 03-18-2009, 12:57 PM
ISpeed2day's Avatar
high temp engine paint will work on the flapper boxes but for the heat exchangers you will have to use header paint as a minimum. Jet Hot is better but expensive.
Old 03-18-2009, 06:15 PM
