-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Head stud nuts stuck - how to remove? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/464343-head-stud-nuts-stuck-how-remove.html)
neil30076 03-21-2009 05:52 PM
Pulled both heads on my 1.7, on one the head studs came out with the nut, and no way will it come loose. I have soaked in PB blaster for over a day ( head upside down and nut/stud in a jar of PB).
What is the prefered way to get the *** nut off?
Heat? Cut the nut off part way with a dremel and split? or what?
Any advice appreciated...
TIA
neil
Dave at Pelican Parts 03-22-2009 12:18 PM
Heat is a very good thing to try. You'll need to set up the stud in a soft-jawed vise to keep it from turning, of course. Some tapping on the nut can help penetrating oil soak in, but heat is probably the way to go.
--DD
neil30076 03-23-2009 03:06 PM
Heat was good, thanks Dave.
