-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   901 synchro hub for first gear (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/470170-901-synchro-hub-first-gear.html)
neilca 04-21-2009 06:41 AM
Here is a tough question I have been noodling for a week, still cannot figure out,
Why is the synchro hub on the first gear of a 901 box different from the other hubs? They all use the same synchronizer. Can you use 2-5 hub on the first gear?
Thanks,
neilca
Joe Ricard 04-21-2009 07:00 AM
No, 1st gear only has one brake band. Obviously it works only in the forward / upshift direction.
It might work if you swapped in a hub. Let us know as I got a box of hubs .
neilca 04-23-2009 06:11 PM
I decided to go ahead and try replacing my first gear synchro hub with one from a "N" gear set I had left over. Everything went fine. I used a bearing puller and a press to remove the old hub and then used the press to put the new hub on, no problem. I used the two spring internals and reassembled the box. shifts fine.
I am guessing Porsche used the unique synchro hub on first to make it easier to engage the gear from a stop. The other gears get engaged at speed. My car is a race car so I am not too concerned hoe easy first is to engage, I will only use it in the pits.
I have not driven it yet, I will follow up with how well it engages while stopped.
neil
