Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 914 & 914-6 Technical Forum
VARam1500's Avatar
550 spyder kit
Hi!
I've been away from these boards for a long time! When our first son was born five years ago, a lot of life went on hold. Those Johnson and Johnson commercials that say "a baby changes everything",......whew, they weren't kidding!
Anyway, I also went back to school a couple of years ago. I took my 914 off the road and it's really suffered from neglect. The last time I went to get an inspection sticker, I failed because of so much rust in the box members under the doors. I had noticed that the more I drove it , the more the doors stuck!
Now I'm trying to figure out what direction to take it. I need a fuel pump before it will run, but otherwise, it shouldn't take much to get it going. I had looked at some 550 spyder kits as a possible alternative for my good-mechanicals/bad-body little project car. I did some searches and couldn't come up with much about "converting" a 914 into a 550. That kinda surprised me. Is there any fundamental reason it's not done? What am I missing? It seems like a good option since some of the kits are reasonably affordable (for tube frame and body).
Anybody have experience with this?
--Case...
'75 1.8L L-jet 914
Old 05-06-2009, 05:53 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Tobra's Avatar
There is a cat named Jake Raby who is a type IV builder who I believe built a 550 with a big 4 in it, think he even posted all about it on his website
Libertarians: Actively plotting to take over the world, so we can leave you alone
Old 05-06-2009, 07:56 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Originally Posted by VARam1500 View Post
Hi!
--Case...
Most 550 kits are made to be used with a custom frame, except the 550 that fit on
a VW pan. The 914 is a unibody car, if you cut someting out you have to replace it
to get the strength back.
Old 05-11-2009, 07:52 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
VARam1500's Avatar
I was looking at the Thunder Ranch offering. It comes with a tube frame. I know I can use the engine and transmission in it. I guess what Iím wondering is if I get a frame, floorpan, and body, can I use my 914 front suspension (control arms, struts, rack & pinion, spindles) and rear suspension (trailing arms, etc)?
If thatís possible, how much work would I need to do to make it work? Or, how much could they do to the frame to prep it for as much of a ďbolt onĒ transfer of these things as possible?
Ideas?.... Discussion?...
(BTW, I didn't see anything about this on Jake's website. If it's there and I'm missing it, someone post a link.)
'75 1.8L L-jet 914
Old 05-12-2009, 11:55 AM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
I think Jake has just supplied engines for Spyder replicas.
As far as I know, all of the Spyder kits either provide the suspension, or use a Beetle suspension. (Mostly the former.) It would take significant amounts of work to try to adapt a 914 suspension to fit and work.
--DD
Old 05-12-2009, 08:05 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Racer Chris's Avatar
Better to repair the 914 chassis than try and find a way to use all the mechanical bits on a kit car IMO.
Any 550 kit will cost substantial $$ to get it on the road, and you will have something good only for sunny sunday drives and car shows.
A 914 in good mechanical and structural condition can be used as a daily driver.
Chris Foley
CFR-Tangerine Racing Products, LLC - 914 Products and Services
Old 05-13-2009, 02:52 AM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
The cars use their own tube frame and most can't easily accept any IRS transaxle..
I have built a couple of these cars and we are beginning the build of a Boxster Powered (3.2)550 with a 6 Speed trans in just a couple of weeks along with the team at Beck.
The Type 4 engine can easily be fit into the car, email me for pics of my car that we built in 2007..
If you buy a car, but a Beck (Chamonix) as Carey and Kevin are the best people in the business and offer the most well built package with the most development. I supply engines for their cars and I know that want to do things right.
I am a dealer for them, so if you want a kit I can probably get you some sort of deal..
Jake Raby
Raby Engine Development
Home of Flat 6 Innovations and Aircooled Technology
'64 356C Outlaw,'76 912E # 185,'76 912E #985,'76 912E #974 Track car
'88 Carrera with 1/4 million miles. 2003 996 Cabriolet, 2004 Cayenne Turbo.
Old 05-13-2009, 02:48 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
TFI TFI is offline
10 yrs already??
Jake, are the Beck cars available in kit form?
Old 05-20-2009, 10:13 AM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
TFI TFI is offline
10 yrs already??
I found my answer. Google is quite helpful.
http://www.beckspeedster.com/whatsadeluxebodypac.html
Old 05-20-2009, 10:25 AM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
I can set you up with one :-)
Jake Raby
Old 05-20-2009, 10:44 AM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Mammalian
96740's Avatar
www.vintagespyders.com
Very nice.
2007 Cayman
Old 05-23-2009, 06:38 AM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
You are headed for expensive repairs. With all that rust the car is flexing in the middle. The
914 has the same wheel base as a lamborghini countach so why they choose the pontiac
fiero as a platform for a kitcar instead of the 914 is beyond me. A 550 spyder is much smaller
than a 914. Older 550 kits used a vw chassis that was cut in half and shortened. You can
repair your 914 if you have a cheap mig welder and buy new boxes although a lot of work.
I believe 914's are coming in more demand.
Old 07-05-2009, 02:21 AM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Mammalian
96740's Avatar
2007 Cayman
Old 07-05-2009, 08:48 AM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
