 Question Re Replaced Throttle Cable We just replaced the throttle cable on my 914 2.0 with carbs . Works fine but sometimes when I go into third gear it hangs up and the engine continues to rev . Correct cable was kind of expensive so I wont drive it until I figure this out as I dont want to replace it again real soon . Thanks for your input |
 ...Or with the clutch cable.  Very common to do that; look up at the front of the center tunnel to check the cables. --DD |
 Great input thanks , it seems to be fixed . Much obliged to both of you |
| All times are GMT -8. The time now is 04:46 AM. |
