moparrob's Avatar
(Maybe) The last RX-7 oil cooler post ever
We can only hope, right. I just bought an RX-7 cooler (1990) off evil bay and it looks pretty good. It is this style:
I have a good idea on how to mount it but my question relates mainly to the oil pressure limiting device inside the housing.
Believe me, I have read at least 20 posts from over the last ten years having to do with these coolers so I understand the majority of the issues. My question is simply what is the device inside the cooler that looks like either a thermostat or a pressure relief valve?
The next question is: if I am running a Mocal thermostat is there any reason to keep this limiting device?
I've heard people call it a thermostat and that it needs to be removed from the cooler to avoid potential problems with it failing. Since I will be running an external thermostat I don't want redundancy.
The next question is: If it needs to come out do you simply discard the old thermo and bolt it all back together? I read some posts where they talk about removing it then tapping the internal passageway and then plugging it with a plug. This sounds like a lot of work.
Someone else said you have to cut the side of the tank off and re-weld the cooler back together. Pass on that..
SO, once again I come begging for help. Any info you have on this issue would be greatly appreciated.
Rob
Old 10-29-2010, 09:45 PM
moparrob's Avatar
This is the offending part I am talking about:
There has to be someone who knows about disabling/bypassing this device, no?
Old 10-30-2010, 08:58 PM
moparrob's Avatar
Never mind, I figure it out from some more searching:
I was wondering since you didn't mention anything about it, what did you do with the thermostat/bypass in the cooler?
Tom
It should be removed, and then a small bolt put in place. An M6 nut and bolt and some crush washers are all that are needed to block off the small hole.
Old 10-30-2010, 09:11 PM
