-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   won't rev help please (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/488544-wont-rev-help-please.html)
plyhammer 07-29-2009 03:29 PM
I have a 71 with msd ignition. The car starts and runs just fine until it is up to temperature at which point it won't come off of idle? Guesses to condition? thanks
jess p 08-06-2009 09:58 PM
Check all your hoses, especially the one to the distributor. It sounds like
you have a vacuum leak. The oil cap on these cars is notorious for this as well.
tab tanner 08-07-2009 05:14 AM
Head temp sensor
John Rogers 08-07-2009 09:53 PM
Need a bit more information: carbs or FI, if carbs what type of distributor, does the MSD box pass it's test with a MSD test unit, what is the timing in total degrees and at what RPM, what do the plugs look like after running?
