-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   1.8 Header to 2.0 (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/490132-1-8-header-2-0-a.html)
S.V.I. 08-06-2009 11:12 AM
1.8 Header to 2.0
Does anyone know if an aftermarket header for 1.7/1.8 engines will bolt up to a 2.0 engine?
I'm not worried about where the tailpipe exits out the rear, I'm referring to the flanges where the stock muffler bolts to the heat exchangers, is the flange pattern and spacing the same?
Thanks, Reggie
Joe Ricard 08-06-2009 12:14 PM
No flanges are normally different but nothing an air power burr bit can't fix.
Dave at Pelican Parts 08-06-2009 10:02 PM
The spacing between the flanges is different. They are also a different distance off of the ground.
--DD
S.V.I. 08-07-2009 07:15 AM
Thanks fellas SmileWavy
