-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   can anyone post up the wiring on back of gauges and where it goes? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/501595-can-anyone-post-up-wiring-back-gauges-where-goes.html)
buggyboyshane 09-26-2009 03:07 PM
hi guys, ive just got a beetle that has 914 gauges in the dash, black centres, possibly 74-76, havnt really a clue but just guessing.
http://img.photobucket.com/albums/v3...ABCD0004-2.jpg
anyway, im trying to hook up the wiring in the correct order can anyone help?? hope my pics help.
fuel gauge/temp gauge
http://img.photobucket.com/albums/v3...ABCD0003-3.jpg
and the tacho
http://img.photobucket.com/albums/v3...ABCD0002-1.jpg
and wiring from the back......
http://img.photobucket.com/albums/v3...ckofgauges.jpg
please help guys, the cars provisionally sold if i can sort this!
many many thanks from a newbie.....
bowlsby 09-26-2009 03:31 PM
http://forums.pelicanparts.com/uploa...1254004288.jpg
:cool:
Dave at Pelican Parts 09-26-2009 09:45 PM
The combo gauge wiring is not quite the same as for your combo gauge--the diagram shows the wiring for the fuel gauge, but not the temp gauge. The temp gauge wiring (the round plastic plug in the back of the temp gauge module) will be +12V, ground, and the temp sender wire.
The sender wire plugs into the "G" terminal.
--DD
buggyboyshane 09-27-2009 01:01 AM
by far best forum yet!!! might just need to figure out what the wires actually do now dave if possible- all except the ground/ earth ones!:rolleyes::)
brill diagam too! thanks a million.
Dave at Pelican Parts 09-27-2009 08:37 AM
Black with blue stripe is "hot" when the headlights or parking lights are on. In the 914, the voltage is controlled with a dimmer or variable resistor so you can change how bright the gauge illumination is.
Red with a white stripe gets power any time the key is on.
Brown you already know about.
Just about all of the other colors on there are signal wires.
--DD
buggyboyshane 09-29-2009 01:24 PM
--DD
cheers dave and bowlsby, one question- the only problem i have with my gauges is that when i switch key on, indicator bulb in the tacho clicks away, even without indicator arm in gear and the lights all round the car do not flash, its only the bulb in the dash and the relay clicks away too................... also the warning lights dont work in that unit and yet the side lights illuminate when i pull the light switch on the dash (in a beetle remember)
this leads me to think the wiring to the tacho still aint right....and i think ive guessed whats wrong.
on tacho.......... photo below, +12 (11 on your diagram) goes to switched 12v, - (13) goes to negative, but where does the other contact go(purple and black stripe)? it says 1 on the casing. and would this wire missing cause the indicator light and relay to click??
Dave at Pelican Parts 09-29-2009 08:26 PM
Black with a purple stripe (denoted "black/purple") on the 914 is the tach signal wire. It plugs into the coil (-) terminal, the same one that the points plug into.
According to the diagram above, the blue/white wire is the turn signal wire (on a 914). It looks like it is plugged into a light bulb holder on your tach, which is good. The holder looks like it has two connections on it. If that is really the case, the other connection should have a ground wire connected to it. It looks to be in the wrong location, though, in the parking light indicator position.
The blue/red wire in your pic looks like it is hooked up to the turn signal indicator. I don't know what that wire carries in the Bug. It also looks to be hooked up to a two-connector light bulb, which should probably have a ground wire on it. (Unless that blue/red wire provides the ground for whatever it gets hooked to, which doesn't seem too likely.)
You have white/red wires that look to be hooked up to the instrument illumination lights. Is that what circuit they are on? Check for +12V when the headlights or parking lights are on.
On the combo gauge, it looks like three of your lights are two-connector ones, while two only have a single connector. The two-connector ones always need some power and some ground to go to them; often the power is "switched power" (red/white in a 914) that is "hot" when the key is on, and the ground is provided by the sender of whatever signal is being shown. (There are one or two exceptions, like the alternator light.)
I can't really tell what that blue/yellow wire is doing on your combo gauge. It looks like it is trying to be a power or a ground for both?
You need to figure out what the wires in your car do, and match that up with what the 914 gauges want to see. If you have a wiring diagram for the Bug, that will make it easier. If not, you will need to dig into there with a multimeter and see what has +12V under what circumstances, and what is grounded when.
--DD
buggyboyshane 09-30-2009 02:17 PM
hi dave, im at a total loss here, at that +12 terminal, there should be a switched live? yes? ok........ from my switched live in fuse box it goes to my combo gauge, i can get all warning llights working in correct sequence. then it continues from the combo to +12 on the tacho. i also have it earthed, leaving only the 1 terminal with no connection (this should go to the coil).
with regards to the bulbs;
the 2 red and grey wires go to side lights, which work perfectly and illuminate the tacho when light switch is on.
the blue and white is high beam (does not seem to work)
and blue and red are indicator(flasher) which goes all the time at in increased rate when the key is turned, although flashes correctly when left or right turn is selected and hazard switch is selected.
the bulbs themselves for the sidelights have only one terminal, so take it they must ground through the case itself. the other bulbs in the tacho have one main terminal which a link (eg indicator flasher) can be attached to but the other side small and not meant for connecting. as a test, i ran wire from switched fuse to the spare unusable side of the light, but....... fuse popped. what the heck is going on?? everything else in the car works a treat, except this one thing! please help guys.
what im thinking is i still have no power as such to the tacho housing (+12)...... will the missing connection to the coil have anything to do with my problems?
is there any way anyone out there could test this for me by simply pulling tacho connection of coil??
any other ideas??
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
