sweater914's Avatar
Lightbulb 40 IDF or 44 IDF which ones to get?
I've got a '72 914 with the 1.7L engine. Right I'm using 40 IDF 19 carbs that apparently are not the right ones, i've been told that they've been jetted and made to work with 356s, the main venturi 36. I believe the carbs were thrown onto the engine as an after thought.
Trying to remedy the situation which carbs should I purchase 40 IDF or 44 IDF?
Old 11-10-2001, 08:23 AM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Just change the Venturis to 32mm and they should run better of course you will need to rejet the carbs to some like 55 idle. 130 mian , 170 air, F6 or F12 emulsion tubes. Set timming at 32BTDC. Steve
See: for tunning tips: www.teglerizer.com/dcoe/webertune.htm
Old 11-10-2001, 08:35 AM
sweater914's Avatar
The biggest problem is the car has a hard time idling and the poor thing backfires pretty bad when I let off the throttle. The car has a Supertrapp exhaust and header. Also it runs rich all the time, as evidence of the black soot on the luckily chrome bumper.
The idle jet number is the only one close. I don't have the numbers in front of me but this is what i do from memory:
idle 55 or 50
main 155
air 115
emulsion F10
Old 11-10-2001, 08:44 AM
RETIRED
Joe Bob's Avatar
You might want to consider an 050 dizzy, I would bet that you have the 009.....
Old 11-10-2001, 11:03 AM
sweater914's Avatar
if you're talking about a bosch blue coil, yes it has a 009, or the distributor?
Old 11-10-2001, 11:48 AM
RETIRED
Joe Bob's Avatar
Yeah, the 009 distributor is junk....get a 050, more advance.
Old 11-10-2001, 12:12 PM
DSPTurtle's Avatar
Porsche Crest
I was reading my SCCA rulebook today and it says that you can go up to a 40 for the prepared class. Not sure if this matters to you but going to the 44 may throw you into a class that is gonna be impossible to run in!!!
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 11-10-2001, 08:36 PM
sweater914's Avatar
not really worried about running SCCA just yet, just trying to keep the poor thing running until after college, it getting a full blown restoration after school loans are paid back, thank though
Old 11-10-2001, 09:15 PM
Conrad W Peden's Avatar
The backfire may be a symptom of an exhaust leak or backpressure issue. The problem with just chucking a fancy exhaust on a motor such as a 1.7 is that it cant take advantage of what the exhaust has to offer. The 'note' of the supertrap maybe masking the leak if there is one.
When a motor is designed to wind up fast and rev high it needs an exhaust that the motor doesn't have to push the exhaust through. Not your typical 1.7.
A mechanic once likened it to having your backside open an inch all the time. If you were in a big rush its not so bad but its not quite practical for everyday use. Having an exhaust like this can make the car tough to tune. He told me to get rid of mine before he would waste my money tuning my car.
My motor is a 1.9 L, high compression with a mild/med cam and he told me I still should be using stock type exhaust. We ended up tuning the car down to run on pump gas anyways.
Good point on the carb size for SCCA rules I know in PCA just having carbs is a big penalty.
We'll be having an ISO9000 audit soon.
I've divided our preparation tasks into two groups: Unethical and Unproductive.
Old 11-10-2001, 09:20 PM
sweater914's Avatar
pretty sure its a back pressure issue the exhaust doesn't have any huge leaks to cause the backfires(small one around the clamp for the trapp), trying to make do with what i have, will have to play the setup a little
Old 11-10-2001, 10:02 PM
