Shift coupler bushings
Hi everyone:
I am in process of changing all of the shift bushings on my '75. I am having a problem figuring out how to get the cross pin out of the coupling that connects the shift rod to the front rod right behind the firewall. I have the old bushings torn out, but I can't figure out how to get the pin out. Does it require some sort of press? Thanks.
Mark Howard Baton Rouge, Louisiana 2023 Taycan GTS |
Hey Mark,
It should be held in with a threaded Alen screw/pin like the one pictured. It’s a real bugger to get out if it’s stuck, but it should come out. Hope this helps.
Tim timw700@hotmail.com Last edited by TimW; 11-22-2001 at 09:53 AM.. |
That "pin" is pressed out, than pressed back in after you get the two (2) bushings oriented into the shift coupler and rod assembly.
Pouding it out with a hammer and drift is done at your own risk. I took the whole shebang to my machinist and $20 got it all fixed up right. ![]()
Rouser! Last edited by Rouser; 11-22-2001 at 12:07 PM.. |
I used a socket that is larger than the pin but smaller than the aluminium joint. That way I am pounding on the pin and the steel shift rod not the soft aluminium joint.
Just to be clear the Alen screw above would screw into the top thread on Rouser’s left coupler picture. That’s the one I was talking about.
Tim timw700@hotmail.com |
I recently changed the bushings and pin. The bushings were gone completely with only the pin holding the two shafts together. Thirty minute job, right? Hah! Took me nearly six hours. I began by trying to tap the pin out... think it moved about 1/8 inch. Then I thought of pressing it out but did not wish to remove the rear rod to which it is attached, so I tried using a C-clamp. That worked somewhat but only moved the pin a little ways out. I finally had enough pin protruding to get a grip with a pair of Vise-Grips. I clamped down hard, worked the pin back and forth repeatedly and finally the pin with thirty-plus years of never moving finally came out.
The bushings seem to be molded nylon (I think) and one did not seat completely. I had to use an Exacto knife to trim a slight shoulder enough for the bushing to seat. Then came the task of inserting the pin. The pin was a tight fit through the bushing before ever reaching the metal rod. But again the C-clamps were the answer.. it was a slow process but the pin was eventually pressed through the bushings. Result? Why did I put off this job for so long? Shifting is now smooth as silk and well worth all the aches and pains this old geezer accumulated. |
Well, I am into the job right now. I took the rod out, changed the ball cup and the rear slide bushing no problem. I have decided to take the coupling and pin to a machine shop.
Just a few suprises. The PO had manufactured his own coupler bushings! Someone used some thin cardboard around the pin and surrounded the cardboard with slices of heater hose! I think I was in shock when I pulled it apart! No wonder my car shifts like crap. New question. How the hell do you get the firewall bushing up front in the hole? I plan to take the front shift rod today and see if that helps the fit, its just too tight and very little room to work.
Well, I'm all done! Took the coupling to my local wrench and he fixed right up with his press. Everything went back together with no problems. What a difference! The stick is so much tighter now, and I can find 2nd gear on the downshift everytime! Should have done this along time ago. However, 4th and 5th are a little tight, but I am sure they will loosen as the bushings wear in.
Feels good to finish a job like this with great results!
Banned
T really make a 914 shift sweet you need to make sure the Motor Mounts and Tran mounts are in Good shape.Steve
