Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 914 & 914-6 Technical Forum
Question Steering wheel and horn connection?
My car is a '74. On the back of the steering wheel the small post that the horn wire connects to is broken off. Has this happened to anyone else and is there a usual fix? I thought about drilling a small hole in the plate the post was part of and putting a small bolt through it and hold the wire on with a nut. Will it work???
Would soldering put this little tab back on?
Also, as the wire comes out of the column, does it go THROUGH the round hole (located at about 5 o'clock) on the center hub OR does it stay behind it and then gets clipped to post?
I took this all apart about 3 yrs ago. Can't remember how it was. Thanks for help.
Old 03-08-2010, 06:53 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
