Please I need advice
I saw this on the internet. This person lives near me. Could someone please tell me if it sounds like a good deal.
I have a 1974 914 with two engines. One, that has been rebuilt from the ground up, a 1.7, is in the car and the other is the original 1.8 that came with the car in '74. I was driving the car as my daily driver for about 11 months....since the rebuild, and suddenly I had a loss of power.....I took it the same day to my mechanic that works on Porsches when I don't feel like messing with it, and he said that it could be a dropped valve seat or a rod gone bad. There is no engine noise, just a loss in power and a "woofing" sound coming from the driver's side weber carbs. The car has had the frame reinforced.....cut out the rust and reinforced with steel welded into place..... the engine has had the cam re-worked by D Elgin cams in California to boost the HP just a bit, but not enough to make it a drag car. I replaced the front braking system.....calipers and all....replaced the struts, brake lines....springs in the rear....new twin Weber 40 IDFs new ignition system....on and on and on...I am a med student that just doesn't have the time to go back into the engine, or install the other engine.....I just want out. I put brand new Mahle pistons and cylinders in the 1.7 when I rebuilt her and conferred with Automobile Atlanta throughout the entire rebuild. Like I said, I just want out. I am asking $1200 for the car, and both engines, but it is negotiable |
You are in the ballpark but depends on the color and condition of the body. The improvements are worth 1200. Sounds like the engine was tuned lean and either burned the valves or sucked the #3 piston. Not unheard of. If allowed I would check the timing as it sits. I would get a leak down test on the cylinders and do a compression test. Then adjust the valves, if you get that far, and compare the compression numbers. Good luck.
