mike mueller's Avatar
Thumbs up L-Jet 2.0 is alive and running (finally)
After a few setbacks, I finally fired up the '75 2.0 tonight, the biggest stumbling blocks were the very slow cranking engine which was traced to the frozen 140amp GM alternator I installed.
The alt spun fine when it was first assembled on the engine on my workbench. I didn't bother looking at why it was frozen now on the motor, I just removed the belt and will deal with the alt later on.
The other problem I had was that my Air flow meter was not working properly. After many hours of trouble shooting the wiring harness and sensors and relays, I finaly tested the AFM.
Haven't had the chance to drive it yet, too late and the car is a tad bit too loud still...don't need to piss off the neighbors yet....
'73 914, 1.7, with Boxster transmission in the future?
Old 12-31-2001, 12:13 AM
Was your engine a 1.8L L-Jet before it was transformed into a 2.0L ?
Old 12-31-2001, 10:08 AM
ShawnO
Guest
Posts: n/a
Congratulations!
Old 12-31-2001, 10:18 AM
The engine was originaly a '75 smog 2.0 motor. (now it has higher compresssion with Euro P/C's), ceramic coated this and that.......still has stock exhaust, not sure what system to install...
next will be the larger throttle body and AFM and some dyno time........
Old 12-31-2001, 11:47 AM
Send a message via AIM to JP Noonan
Seems we just can't let Dr. Porsche do all the thinking for us...
I converted a 1.8L that was converted to Carbs by a PO to a 1.7L/2.0L D-jet. And aslo my 2.0L stock L-jet 912e into a D-Jet, again due to a PO using carbs. I'll get the L-Jet back on it eventually.
93 Lightning
76 912e
Old 12-31-2001, 01:53 PM
