Steering wheel ??
Ok I found that I did not have the Plastic extension piece for the back of the wheel.
Kenny sold me an almost complete wheel I have the parts to Complete the wheel now. Should the cancelling Ring dog be clocked at 3:00? Why soes every auto parts store only stock 4mm as the smallest screw? I need 7- 3mm Screws for the assembly. The wheel that I purchased on Ebay Has a Horn button with out the connector for the horn wire. Did some of the 914's just have spring plunger to make the horn contact. Thanks Glen There has been a VW in my family since 1959. |
Got her done
Well I clocked the canceling ring at 3:00 and changed the screws on the contact canceling ring to 6-32. The center rubber cone did not have enough spring left to stop the butterfly from rattling so I added a piece of dense foam to it and now it fits fine. Beep Beep
![]() Glen |
Early cars '69 - Mid '72 had the spring loaded button. Later cars just had the ground wire come up through the hub and attach to the horn pad.
Ron Meier Backyard Shadetree Mechanic 1974 914/6 conversion with 2.7L (The Grey Ghost) 1973 Chalon with 2.4T MFI (Schlitzalom) All my 4 cylinders are gone
Glen |
