Green with a Red stripe
Hi all;
I have an issue with this wire. When I changed the coil awhile ago (restoring) I thought this wire went to the - side of the coil. I just turned it over and found I have no spark with it hooked up to the - side. but when I unplug it I do. Right now I have only the black wire to pos. Tach (purple black) and green from the dist to the neg side. This wire also has a small amount of current coming through it. Could it possibly go to the + side for starting? Any help would be appreciated. I have scoured the forums but couldn't find any discussion on this wire just the black, tach and dist ground wires. Thanks DK http://forums.pelicanparts.com/uploa...1274653187.jpg |
What year teener? I have colored wiring diagrams ans could look it up for you.:D
I knew I forgot something. It's a 1973 1.7
thanks DK |
That's for the oil pressure light. The "idiot light" sender is near the distributor, but screwed into the crankcase.
The wire that brings power to the coil (+) terminal is black and should have a red stripe, though the red can fade a lot over the years. The tach signal wire connects to the coil (-) terminal, is black with a purple stripe, and is thinner than the coil power wire. The wire from the points/condensor to the coil (-) terminal is green. --DD |
Thank you very much
DK |
That's the sender for the light.
The white wire is for the fuel injection. That is probably the wire for the thermo switch, which is elsewhere in the vicinity. On the 2.0s, it is on a bracket sticking up from one of the legs of the plenum. Not sure on the 1.7s. --DD |
Thanks again Dave. Very much appreciated
DK |
Maybe you should spent some time looking here first: Pelican Parts - Porsche 914 Electrical Diagrams :cool: Andy |
Can anyone help? Thanks DK |
Did you replace the seals on the oil cooler? If so, you probably pinched one when reinstalling the cooler. It's easy to do. The cooler sits right above the oil-filter which can make it look like the oil is coming from the filter. SmileWavy Andy |
Thanks again Andy DK |
