No 5th Gear
So I have a 1975 914 1.8 and i had the engine and transmission rebuilt about 2000 miles ago. All the sudden the other day 5th gear stopped working. I have checked to make sure nothing was getting caught up with the shifting rod and all the connections are good. I also spent about 4 hours adjusting the shifting and I could never get the car in the 5th gear. It feels like it’s almost there but kicks it back out. I was able to get it to grind a bit in to 5th gear. It will run in all the other gears no problem at all… I am thinking there is a problem with the transmission but thought I would get some other opinions any thought would be great.
Thanks,
Troy
Old 06-13-2010, 01:51 PM
By adjusting do you mean at the shifter handle to rod interface?
If you loosen the clamp and push the rod further into the clamp then it might engage 5th.
Can you get it in 5th from the shift console at the transmission? disconnect the shift rod.
If it goes in 5th then it is back to your adjustment of the shift rod.
If it can't be shifted into 5th then it is inside the gear box. This is actually very easy to take apart.
Old 06-13-2010, 04:27 PM
canna change law physics
red-beard's Avatar
Joe is right. You CAN remove the gear stack without pulling the whole tranny. I did this once just to prove it could be done.
James
Red-beard for President, 2020
Old 06-14-2010, 01:35 PM
