toman's Avatar
fuel pressure with carbs
hey guys, I have been wondering about what effect fuel pressure has on a car with carbs. When I got my 914, it had dual webers and a pressure regulator; I'm not even sure what the regulator is set at. But is there one setting that is reccomended? Or is it something that can be tweaked? Thanks in advance, my curiosity was getting to me on this.
Old 12-17-2001, 11:00 AM
ShawnO
Guest
Posts: n/a
Everything I've read and heard is 3-5 psi on Webers.
HTH
Old 12-17-2001, 11:54 AM
jabb's Avatar
I run my Webers at 3 1/2 LBS put a perssure gauge in line before the carbs if you want to see what you are running at
  • Joe A.
  • 84 911 Targa
  • 75 914/6 3.0
Old 12-17-2001, 03:39 PM
Ron Meier's Avatar
Street 3.5 psi
Track - 5 psi
to much pressure overrides the needle valves and floods the engine.
Old 12-20-2001, 11:12 PM
