-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   How do I remove the throttle position switch? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/548093-how-do-i-remove-throttle-position-switch.html)
magaoidh 06-15-2010 02:25 AM
OK I know there are two screws one either side but there is a female connection on the TPS which appears to lock onto a shaft from the throttle body.Anyone know the trick?
magaoidh 06-15-2010 03:17 PM
There is a locking tongue inside the female connection and I am sure it locks into a groove on the shaft,someone must have removed one???
Dave at Pelican Parts 06-15-2010 07:14 PM
Pull and wiggle, I think that's how I managed. I forget if I had to pry to get the TPS off of the throttle shaft; if you do so be careful not to bend the shaft!
--DD
magaoidh 06-15-2010 10:25 PM
Thanks Dave how are you doing,had another look at it and its a shaft with a flat on it for correct alignment, all done and an improvement on the bucking.BTW the return spring , is it better to have a stronger one or???
Dave at Pelican Parts 06-17-2010 09:52 PM
I've been better. (Long story.)
A stronger spring will generally mean more wear on the throttle body, throttle valve, and bellcrank. You want the spring to be strong enough to close the throttle valve, plus a little bit more for safety margin, and that's it.
--DD
Dave at Pelican Parts 06-23-2010 08:45 PM
As far as I know, the TPS is held on by screws, not rivets.
--DD
magaoidh 06-23-2010 11:53 PM
Dave is right!
