fuel pump not running on my 73 2 litre
I am starting to lose my cool with this car.Bought it in 2006 and got it registered last month.
Car has had bucking probs which are ongoing,I have changed to a spare TPS.The car runs perfect when cold but on a second test run there is a bit of bucking not major but annoying.
I have a spare ECU,correct one for the car so I believe,I hooked it up and went to start the car and there was no fuel pump running,needless to say no start.So I went back to the original ECU and you guessed it, no fuel pump running so no start.
All I did was change the ECU,now I have a car that is still bucking and no fuel supply.
Anyone help with the fuel pump mystery please,I can live with the bucking but the car is now immobile!
Old 06-28-2010, 01:44 AM
SirAndy's Avatar
The fuel pump is controlled by the FI brain ...
- Check the connector on the brain and make sure it is seated correctly.
- Did you unplug the brain from the relay board? If so, make sure that connector is seated correctly as well.
- Check the fuel pump relay and switch with a known to be good one. The headlamp relays work fine for that.
Andy
>> 1970, 914-6, 3.6L TT4/AX4 - Shall I say... 3.6 (My conversion thread)
>> 1970, 914-6, #374 (Original) For sale!
Old 06-28-2010, 09:49 AM
racer's Avatar
While you are checking relays, it won't hurt to remove the relay board and look at the underside. Not uncommon for the boards to completely "dry out"- look like a dry lake bed - which makes the connections suspect.
Did you check to see if you have power at the fuel pump itself? Maybe the pump has gone bad (especially if its original).
Past:
2000 Boxster 2.7, 1987 944
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 06-28-2010, 12:32 PM
Andy
Andy,
The connector was not a real snug fit so that could be the problem.I have changed the pump relay to a spare with no change.
Where is the switch,or is that in the relay?
I left the brain connected to the relay board!
Geoff
Old 06-28-2010, 02:26 PM
It may be original I will check today,thanks
Old 06-28-2010, 02:27 PM
The latest news is that I checked the pump with 12V and it ran,I then checked the connections from the harness to the pump.
After that I checked the connection to the brain and carefully aligned the plug in and voila the pump ran etc.
Thanks Fellers
Old 06-29-2010, 12:44 AM
