-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   testing emerg flasher switch.... (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/550441-testing-emerg-flasher-switch.html)
Idcelr8 06-28-2010 03:06 PM
I am trying to bench test a flasher switch. The electrical diagram was helpful, but I still have a few questions.
The lug on the side... This appears to be a ground. Should I get contunity between it and the body of the switch? I have no current between it and any other lug with switch open or closed. It appears I have lost the ground to electrical resistance if this is indeed the ground.
With switch open I get current from 49a to L and R; no current when switch closed.
With switch closed I get current from (+) to 15; no current between the two with switch open.
With switch open I get current from (+) to 30; no current between the two with switch closed.
The light bulb tests good.
Any suggestions?
