Is this hell?
How bad is this? Can the car be used for a while or should I start welding? Thanks for looking, Joel
Old 07-23-2010, 06:07 AM
Rust never sleeps
Yes that is hell.
Old 07-23-2010, 06:30 AM
If there is worse than hell THAT WOULD BE IT.
Old 07-23-2010, 08:01 AM
gearhead
That picture of the driver's side makes me worry that this is one of those cars that want's to break in half.
Do the doors bind on closing while you are sitting in it? How are the jack points?
1974 911 Restorod
1974 914 Bumble Bee
1975 911S Tom's Targa
2008 Cayman S Mule
Old 07-23-2010, 08:02 AM
A=F/M's Avatar
I nominate this as hell on Earth... or hell driving on Earth! This is usually the "tip of the iceberg. Brother, you must now exorcise the demon... Can I have a hallelujah!!
Old 07-23-2010, 12:05 PM
Only fix for this car is a pck of sawz-all blades.
Old 07-23-2010, 02:25 PM
and a dumpster
Old 07-23-2010, 02:26 PM
amen brothers
Thanks for the honest opinions. I am going to start investigating further with a die grinder and vacuum cleaner and see if I can hit some meat It does not bind at the door closing yet. Does anyone have a detail plan for just putting in a roll cage? Thanks oh me brothers...J
Old 07-23-2010, 05:44 PM
I have had a car that bent in half. It was not rust in the door jambs that did it. It was rust in the area around the jacking points.
Of course this should be fixed as it will not heal itself, but if the jacking points are still any good at all this car could likely be saved.
It will take a lot of work.....
Old 07-23-2010, 07:23 PM
Thats what mine looked like and this is what was under it after blasting. Results may vary!
Old 07-24-2010, 12:38 PM
The jackpoints in my 73 were both rusted, but the car had little other rust. My body guy replaced the jackpoints. It takes some creative welding to do it right.
Old 07-27-2010, 03:23 PM
