How to reset e-brake dash light
I am rebuilding the rear calipers on a 1975 Porsche 914 1.8. Just wondering if anyone has an experience on how to reset the e-brake dash light after the rebuilding is complete? Car has been in storage for 1 year. Calipers are seized up and the light keeps blinking. Any suggestions?
Thank you.
Old 08-30-2010, 07:40 AM
E Brake..
There is a small switch on the Master cylinder that you can reset...I have the same problem and could not find it but i did check the small switch at the base of the E brake when you punch that in it should go off...mine did for a while and then it started blinking again so I am still looking for the supposed reset switch...
Old 08-30-2010, 08:10 AM
If there isn't a button on the M/C (mine doesn't have one), then remove the switch with a wrench and screw it back in.
Old 08-30-2010, 01:19 PM
