Engine won"t idle
I just bought a 1974 914 LE
While going over the engine i found a wire that was disconnected from the temperature sensor on the intake air distributor. So i plugged it in and the engine started to run rough then stalled. I removed the wire and it idled fine??? Would a defective temperature sensor cause this to happen? Now I know why it was unplugged. Any thoughts. How can i test it? Thanks Terry |
Learn this website, my son, and for as long as you own a 914, make it your bible:
914 D-Jetronic Parts and Troubleshooting Seriously, the part you describe is the intake air temp sensor. Some people disconnect it to richen the mixture. |
Thanks for the link to the web-site. It will come in Handy for sure!!!!
1974 914 LE 1985 911 euro 1990 944 S2 |
| All times are GMT -8. The time now is 12:47 PM. |
