-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   914 powered 356 ? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/56406-914-powered-356-a.html)
Higg356 01-10-2002 12:26 AM
914 powered 356 ?
Anyone done a 356 outlaw upgrade using a 914 as the power plant
What is required ?
Target car is an open "A"
Especially interested in those where a High Power 914 (>2.2L) was used with a 741 or 901 trans
I know about the Flywheel <200mm for a 741
What running gear was used ?
Best Gear Ratios?
What Brakes / Suspension Mods are needed?
What Trans/Engine mount Mods needed to handle the extra torque?
Would really value the advice
Cheers
maf 914 01-10-2002 05:58 AM
This isn't much, but several years ago Excellence magazine did an article about a 356 that had been prepared for the current historic version of the Pan American Rally. (Is that the correct name?) The car was beautifully done and they used a type 4 for durability and torque. It may help if you could find a copy of that article.
Mike
