914 gear chart?
Can someone post or send me a gear ratio chart for a 914 with stock gears?
Thx.
Old 11-24-2010, 11:37 AM
jhora's Avatar
Go here...
901 transmission - The Porsche 914 Wiki
Stock..
914/11 A F N V ZD
914/12 A F N V ZD
John
Old 11-24-2010, 12:45 PM
gearhead
If you want an excel spreadsheet you can plug things into, shoot me an email at gtgears@yahoo.com Be sure to put a title on it. Untitled emails end up in the junk trashcan...
1974 911 Restorod
1974 914 Bumble Bee
1975 911S Tom's Targa
2008 Cayman S Mule
Old 11-24-2010, 01:24 PM
JW Apostate
trekkor's Avatar
gear chart
I run c-f-m-s-x.
Nice set.
KT
'74 914-6 2.6 SS #746
'01 Boxster
'73 914
Old 11-26-2010, 01:59 PM
ExcellentKT! That will work.
Thanks everyone.
Old 11-26-2010, 05:27 PM
JW Apostate
trekkor's Avatar
You got it!
What motor are you running?
KT
'01 Boxster
'73 914
Old 11-26-2010, 05:48 PM
gearhead
trekkor,
What are you running for tires? 22.5" is pretty small.
1974 911 Restorod
1974 914 Bumble Bee
2008 Cayman S Mule
Old 11-27-2010, 06:04 AM
I think most 205/50/15's are close to that size.
Would be nice to see a graph of stock gears. The table is a little harder to work.
Motor would be a 1.7.
Partially wondering if the gear splits are tighter than most stock 915's.
Still in the concept stage.
Thx.
Old 11-27-2010, 09:51 AM
JW Apostate
trekkor's Avatar
Originally Posted by Matt Monson View Post
trekkor,
For the past five years I had been running 205/50/15's, which are 23" tall.
Now I run 13" Goodyear radial slicks!
22x8x13 ( 225/45/13 front ) appr.
22.5x11x13 ( 305/33/13 rear ) appr.
22.5" tall!
It took quite a bit of work to make this happen.
KT
'01 Boxster
'73 914
Old 11-27-2010, 10:35 AM
JW Apostate
trekkor's Avatar
You can use the chart I posted to suit your needs.
Just print it out and highlight your powerband RPM's on lines A-F-N-V-ZD ( stock ratios ).
My yellow highlights represent a full throttle run-up through the gears.
Each '+' before the start of the yellow swipe shows the RPM drop into the next gear after a 7300 RPM upshift.
For example: after an upshift from gear 'c' into gear 'f', results are 45 mph @7300 to 45 mph @5500.
KT
'01 Boxster
'73 914
Old 11-27-2010, 10:46 AM
KT,
Thx.
Fun car!
What TH times can you pull in your 914?
What motor/HP?
Stock gears?
Old 11-27-2010, 01:28 PM
JW Apostate
trekkor's Avatar
I matched my personal best a couple weeks ago, going easy. 2:15
I expect to hit a 2:07-10 in a couple weeks when I return on 12/11,12.
2.6 liter SIX, appr 200hp.
Gear set is c-f-m-s-x.
KT
'01 Boxster
'73 914
Old 11-27-2010, 02:37 PM
Looks sticky!
Sounds fun.
Old 11-27-2010, 05:55 PM
JW Apostate
trekkor's Avatar
Come to the track and have a ride along!
KT
'01 Boxster
'73 914
Old 11-27-2010, 06:12 PM
Thx for the offer.
What club do your run with?
Miss my 86 911. All stock except cat bypass, chip, and 7&9's with MPSC's. Last DE pulled a 2:16.5 at TH but had faster laps in practice.
2:07 would be fun.
Trying to come up with a plan for 2011.
The best.
Old 11-27-2010, 08:55 PM
JW Apostate
trekkor's Avatar
Hooked On Driving in December.
12/2 at Sears
12/11,12 at TH
Come on out.
I have a second seat.
KT
'01 Boxster
'73 914
Old 11-27-2010, 09:11 PM
JW Apostate
trekkor's Avatar
My 2:15 was with the two liter on 205's.
The Goodyear slicks are pretty nice.
Here's a fun video from nearly two years ago!
KT
'01 Boxster
'73 914
Old 11-27-2010, 09:18 PM
gearhead
Thx.
Send me your email addy. I'll get you a chart you can manipulate. I'll include a sample of your '86 911's 915 gearing at the same time.
1974 911 Restorod
1974 914 Bumble Bee
2008 Cayman S Mule
Old 11-30-2010, 12:40 PM
gearhead
22.5" tall!
http://i944.photobucket.com/albums/ad286/trekkor/746%20returns/P1100001.jpg
KT
Oh yeah, I remember now. You were talking about those wheels when I met you at Sears Point last month.
1974 911 Restorod
1974 914 Bumble Bee
2008 Cayman S Mule
Old 11-30-2010, 12:41 PM
