914 fuel pump swap to 75/76 type
Can you switch to a 75 or 76 fuel pump with out any problems ?? I have a 73 with the three prong pump witch is VERY exp to replace....250 to 300 dollars!..the 75/76 is only 100 or so..has anyone done this swap ??
Old 01-25-2011, 07:32 PM
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
It is doable. You need to come up with some adaptor magic to get the fuel hoses and fittings to work together, as they are not all the same size. You would eliminate the "Y" in the return line as well. And I think you might need to change the electrical connector? (Not sure on that last bit.) And it may require a little creativity in how you attach it to the car.
The pressures and flow rates are comparable, and the new-style pump just takes 12V like the old one does. So if you can get it hooked up, it should work fine.
--DD
Old 01-25-2011, 09:47 PM
