16" fuchs on a 914
Will later model 6 x 16 Fuchs wheels (from a 911sc) fit a 914 without a fender modification. I would like to switch to 16" wheels vs. the 6 x15" Fuchs that are installed now.
Old 05-06-2011, 11:14 AM
spoke's Avatar
They should fit if the backspacing is the same. I have 6x16 and 7x16 to put on my 914. The 7x16 in the rear will definitely require the fender to be pulled out a bit.
Old 05-06-2011, 07:26 PM
What year is your 914? The later model 914 - actually had a little metal removed around the flange of the rear flare that makes it easier to fit 6 x 16 fuchs on with 205/55 x 16 tires without having to pull the fenders. Jim
Old 05-08-2011, 12:01 AM
16" Fuchs
Does anyone know the Porsche part number for the right 6" X 16" Fuchs wheel?
Old 05-08-2011, 06:22 PM
spoke's Avatar
The wheel sizes for 911 are listed below.
911 Wheel Weights
Here's a chart showing the wheel backspacing. I think you want 112mm.
My 6x16 wheels are 911.361.020.43 and 7x16 are 911.361.020.44.
Old 05-08-2011, 08:04 PM
Dixie Region R Gruppe
w21055's Avatar
They will fit, I have 4 on mine, switching to 7's in the summer.
Instagram @phillipkj4
1980 911 SC Backdated Viper Green
1992 Ferrari 348TB
Old 05-10-2011, 08:47 AM
7 x 16 fuchs
I have two 7 x 16s if you are interested. $250 each plus shipping. Can send pics
Old 05-10-2011, 10:33 AM
racer's Avatar
as mentioned, 6's will fit but keep tire no wider than 205. 7's can fit, but often need a bit of massaging. There is only "one" 6x16 size/offset available.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 05-12-2011, 08:39 AM
