Question Head help
I need help. I have a 76 2.0 engine. One head has a dropped seat, the seat started coming out but got lodged kind of cockeyed in the head. It didn't totally come out and destroy the piston and combustion chamber. I'm not sure what to do with the head, does anybody know if it is worth fixing, cost?
I want to rebuild the engine with euro pistons, bigger cam and go with carbs, but don't know what to do about the heads.
Any ideas would be appreciated
pete
Old 02-26-2002, 09:06 PM
If it's a 2.0L (3 bolt intake) head, I'd have a reputable head shop weld it up, slap another seat in it and have the rest of them checked, then have them both rebuilt. 2.0L's are getting hard to come by (at least in the Midwest). I have two pair and plan to rebuild and rotate them about every 50K or so.
"Whether you think you can, or think you can't, you're probably right" - Henry Ford
'73 914
'75 914
Old 02-27-2002, 01:14 AM
more power
I would rebuild the heads and get bigger valves in the process. Port polish, cc, the whole 9 yards.
Old 02-27-2002, 06:07 AM
DDS DDS is offline
Ditto what joe says. If the seat dropped and damaged the bore, you've got a load of work anyway.
-- Dave
'73 914, 2056 GT/SC done!
'69 Lotus Europa S2 - under resto.
pics at
http://www.syer.net
Old 02-27-2002, 08:31 AM
Thanks for the responses, does anybody know how much this costs or a reputable shop?
Old 02-27-2002, 12:20 PM
DDS DDS is offline
Greg Aaronson at FAT told me that $1500 worth of headwork is not out of this world for a 'hot' T4. I may have $600 or $700 into mine with no regrets.
For benchmark pricing check FAT or RIMCO or Leitner and Bush in Toronto (pay in CDN$)
www.fatperformance.com
www.rimcovw.com
www.leitnerbush.com
Fat has a published price list that you can request that will give you an idea by operation of machining costs (top dollar IMHO), Rimco may have it on the WEB, L&B would have to be by tel or email.
Jake Raby has recommended Headflowmasters in his video and elsewhere for head work.
Make sure that if you use a non-T4 expert that they use higher than std. crush for the fit of the new seats - that is supposed to prevent fallen seats. (I can't remember the recommended spec)
Down the slippery slope you slide!
-- Dave
pics at
http://www.syer.net
Old 02-27-2002, 12:47 PM
