-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Weilding question (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/610790-weilding-question.html)
KID914 05-26-2011 05:45 PM
Weilding question
I would like to stiffen my chassis,with a kit i am purchasing. I believe it is a 16 or 18 gauge metal. How big a weilder would i need. mig...tig....suggestions.
Thanks Teeners
Mike Bellis 05-26-2011 08:48 PM
MIG. Very easy to learn. Get one with gas. I have a Miller 175 and I'm very happy with it.
Along4ride 05-26-2011 09:56 PM
If you are new to wielding forget about gas/tig. Both require a huge learning curve. Definitely go with a wire feed and get a book on wielding. Haynes has a good one, I actually started off with it. The Miller welders are very nice and will produce excellent wields. However, they are expensive. If all you want to do is wield in a stiffing kit, I would recommended the dirt cheap Harbor Freight 110V wielder. I recently "borrowed" one from Harbor Freight when my MIG was down. I have to say, it did do a great job welding the cracked exhaust header on my 944 T. But I warn you, the corded wire is messy, the flux goes everywhere; so have a wire brush handy. They also make wire wheels that attach to electric drills. Also, a good angle grinder is nice to have if you put down too much wield or want to start over. Remember, a fire extinguisher, gloves and welding helmet are your best friends. Nothing will ruin your weekend faster than your car catching on fire or a trip to the hospital because you UV burned your eyes. I UV burned my eyes when I was 20 because I couldn't see what I was welding through my mask. Huge Mistake, it feels like sand paper rubbing on your eye balls. Get your self an auto-darkening helmet if you have trouble seeing.
rfuerst911sc 05-27-2011 03:24 AM
In my opinion you should only buy a name brand welder. This should be a tool purchase that you plan on keeping long term. I would recommend a Miller, Hobart, Lincoln, Daytona Mig brands like that. Get a brand that your local weld shop sells/services so you can get replacement parts if needed. And don't rule out buying used as many of these come up for sale. I purchased a Hobart 140 and did all the welding on my 914 with it. I did chassis stiffening kits, metal wheel flares and some patch panels and it did a great job. And don't forget good eye protection I like the auto darkening shields. And a good cart, cutting pliers, tip cleaner, various spools of wire, shielding gas, good gloves it goes on and on. Good luck.
KID914 05-28-2011 05:30 PM
Thanks to everyone. I was planning on using (mig), thought it would be the easiest.
Joe Bob 06-17-2011 10:31 AM
My Hobart has served me well.
Jared at Pelican Parts 06-19-2011 11:35 PM
Get a MIG. easiest to learn, most versatile. When you're ready for precision welds, move up to TIG.
Get the highest quality auto-darkening helmet you can, thick welding gloves and coveralls.
Invest in a good angle grinder at the same time.
kachemakian 06-21-2011 09:00 AM
IMHO your 914 is not where you want to learn to weld. If I were you I would haul it to a body shop or welding shop where someone who does it every day would do you a good job. Learning to produce good strong welds takes a lot of time and practice, and is a lot easier to learn by starting out with metal a least 1/8" thick. Thin body sections are very prone to warping from heat and there is a fairly long learning curve to get a good looking, strong end product.
Leon
