Djet Help!!
I am at my wits end. Engine running way too rich and bogs down under acelleration. I have checked dwell, timing, points all to no avail. I have heard the pressure regulator on th drivers side will cause a rich condition if its bad, but how bad will it effect the engine? This cant be the way a engine should be running. Please help!
check the MPS. See if it still holds a vacuum. You can check that by just sucking on the hose.
72 914 2056: 74 9146 2.2: 76 914 2.0 |
Check your temperature sensors. Running rich is a classic symptom of temperature sensor failure.
If you haven't done so already, check out Brad Ander's very complete discussion of the djet for the 914. Rolfe--Edenton, NC |
Got it! MPS would not hold vacuum at all. Had a spare, runs much better. Still need to fine tune my timing but otherwise way relieved. RSCHROED you are pretty close to where i am, you should stop by some time!
