![]() Now the car is this but have a little problem with the front suspension !!! I would mount the oem fuchs I have but for make the combination with the front oem parts and what else need ??? any DYS ?? Thank you guys !!! |
T.C. |
Administrator
You'd want new shock absorbers, new wheel bearings, new ball joints (with the appropriate attachment), rebuilt brake calipers, new rubber brake hoses (or possibly stainless-steel braided hoses). Used parts would be less expensive, but those are all wear items so it's better to replace them. Quote:
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
What calipers and disk brakes would you use in the rear ?
Administrator
Depends on a bunch of things.
The easiest would be to use the stock 914 rear calipers over solid rotors. If you need vented rotors in the back, Eric Shea at PMB Performance can set you up with stock 914 rear calipers with a spacer in the middle to go over the thick vented rotor. People have adapted 911 rear brakes to the 914 trailing arms, including ways to keep the hand-brake functioning. A search here will probably turn up info on that. If you don't need a hand-brake at all, you can use the stock 914 front brakes on the rear over solid rotors. You can also make the 911 rear brakes work without including the hand brake part. And, of course, there are places like Wilwood that make a huge number of different brake setups that can be made to work. If you're going for a duplicate of the 914-6 GT, I'm not sure what they used. Probably different cars used different setups, but I'm not even certain about that. Check the web site I linked to early in the thread for pictures of what the GTs used, and also talk to Eric Shea (again). "Real GT" or replica of the real GT options are likely to be some of the more expensive ones. --DD
Where are you going to use the 914...street or track?
John |
Street and DE.
But if you upgrade the fronts the rears should be upgraded also. |
thank you guys !!!!
For the rear whells I have prepared : The oem hubs with worked to 5 screws, the oem brake disk thins with the work of the 5 holes and with a pair of oem 914-4 front calipers and I not need standard hand brake because I mount one racing hydraulic hand brake. And for the front I have : One new pair of drilled 911 brake disk, one pair of 911 sc front calipers, and the oem 911 hubs with the five screws, and I would mount because I thinking have all parts. Yes !!! Is not the best combination but, when the car are finished, and the engine start Ok, and all of prts works step by step make more modifications, for me the problem is the money,and need go step by step. Time for mount and dismount for me is not a problem, because I make all with my hands, I would mount 4 bilsteins front and rear ¡, because I have time, first for me is more important the combination of the money for the car can work !!! then, to mount the hubs of 911 with the 5 screws, I need the struts of 911? the struts oem of the 914-4 are little ??? Last edited by jm993rs; 06-14-2012 at 11:57 AM.. |
Administrator
You need 911 struts to mount the 911 hubs and brakes.
Hydraulic hand-brakes don't work reliably. At least, not if you set them when you come off the track with nice hot brakes, and then they cool down. Chocks (triangles, often of wood, that you put on the ground to keep the tires from rolling) are fine for race cars. Not so good for street cars. --DD
thank you Sr Dave !!!!
The car is only for make racing of regularity and track days, I not search make exactly clone of 914-6 GT. I search make and have one early auto for racing days but without spending a fortune. what do you think about the dash refurbished ???? ![]() |
Administrator
The dash looks good! I might consider using a 911 oil temp and pressure gauge instead of the 914 combo gauge, but you'll have to either get a fuel gauge or make room to use the 914's fuel gauge somewhere if you do that.
--DD
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too http://www.bvdmotorsports.com Active Rennlist Member. http://members.rennlist.com/racerbvd/ See blog for my For Sale & Wanted List. http://www.914club.com/bbs2/index.php?automodule=blog&blogid=337& |
I'm pretty sure I see an oil pressure gauge on the dash but I agree with Byron, I'd like to see more. Looks great!!!
Nice dash...more close up pictures please
John |
of the dash I only have this pics now !!!! time ago a little group of friends make a little stickers with one little a avatar and group name, but was a 911 silluette and I removed !!!
Sorry friends !!!!
what I'm looking for this struts ???? |
Those struts are equivalent to a stock 914/6 ... 3" caliper mounting spread or "M" calipers.
If you have SC calipers, "A" or "S" calipers, you need 911 struts with 3.5" caliper mounting spread.
Ron Meier Backyard Shadetree Mechanic 1974 914/6 conversion with 2.7L (The Grey Ghost) 1973 Chalon with 2.4T MFI (Schlitzalom) All my 4 cylinders are gone
Exciting to see your progress and a small world as well! The car you are replicating is currently sitting above mine as it mine is being restored. Car looks amazing in person!
Smaller world... I work with the guy that restored the car you're replicating. I had really wanted to build a GT but was scared off by the process and price.
David Artist www.airbostongraphics.com & www.facebook.com/airbostongraphics NARP: 1970 914/6 NARM: 2010 MINI Cooper NARB: 2010 Electra Super Deluxe |
