LinkBack | Thread Tools | Rate Thread |
What a DUNDER Head
Wow Joe, that is not the best of news
![]() Let us know what you decide!!!
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
good excuse for new 96MM
Well it is just money and time. I can always make more money. But it is getting to be spring time which goes so quickly.
So who has a line on some 96MM pistons and Cylinders. I seem to recall they are slip in? |
If it were me, well I'm a cheap bastard, I would use a ball-peen hammer to smooth down any sharp cuts in the piston and head to avoid pre-ignition and then just keep going until next winter.
up to you, most certainly NOT the ideal solution but like I said I'm a cheap bastard. Well actually I'm a Irish redneck from Ohio, but call it as you will...
93 Lightning 76 912e |
I can also agree with JP when the need arises but it has also bit me in the butt. If this happens to be a route you are considering, check the piston for free movement on the rod, check for free movement of the rings, and check for cracks on the underside of the crown and pin bosses. A dremel tool works great for smoothing out the sharp edges. Is this the right way, I'll leave that up to the person making there own decisions on their engine, but it has gotten me by until I was ready to buy a set of pistons and cylinders.
Thread Tools | |
Rate This Thread | |
