Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 914 & 914-6 Technical Forum
LinkBack Thread Tools Rating: Thread Rating: 6 votes, 5.00 average.
gearhead
Armando,
Here's the Singer site:
Singer Vehicle Design
Bespoke hand built retro-chic 911s. $1/4 Million worth...
1974 911 Restorod
1974 914 Bumble Bee
1975 911S Tom's Targa
2008 Cayman S Mule
Old 10-07-2011, 10:28 AM
914-6 GT Resource Page
ajserrano's Avatar
Thanks Matt! I'll check it out...
1970 Porsche 914/6 GT > Recreation in progress... http://www.pbase.com/9146gt/my9146gt
1970 Porsche 914/6 > Crashed, driving while sleeping (not good!)
1974 Porsche 911 Carrera > Stolen, recovered in pieces
Old 10-07-2011, 10:51 AM
gearhead
You're welcome.
And I'll give you one hint where the gearbox upgrades are coming from.
1974 911 Restorod
1974 914 Bumble Bee
2008 Cayman S Mule
Old 10-07-2011, 11:42 AM
ajserrano's Avatar
Matt, what's the going asking/market value of a NOS 904 mainshaft, do you have any idea???
Old 10-07-2011, 11:58 AM
Thank you Matt,for the link,I was just gonna learn to do that.
I am still new to posting and still learning how to post pictures and links.
Old 10-07-2011, 01:54 PM
Mr9146's Avatar
$1500 to $2000 for a factory-original NOS part ... $750-$1000 for new reproductions.
Old 10-07-2011, 05:24 PM
ajserrano's Avatar
Flash-Forward Photo to today...
Thank you for the market value quotes Marco and Matt. The reason I asked is because I located a NOS 904 mainshaft for only $750.
I better run off to the bank tomorrow and don't let that one get away.
I'm a bit tired tonight, so I'll just post a couple of current photos for now. It will be an update to my post #72 photo.
You can see the rest of the sequence starting here DSC05942.jpg photo - 914-6 GT photos at pbase.com
I'm speechless, don't know what to say...
PS: Keep in mind we are NOT quite done yet, two more days, maybe Monday and we can all see the final results, top and bottom!
Old 10-07-2011, 10:33 PM
ajserrano's Avatar
BEHR Front Oil Cooler Installation
Okay, now back to where we left off earlier. Next is the installation of the BEHR factory 914-6 GT front oil cooler, here are some photos...
This photo shows the large opening cut-out needed for the BEHR front mounted oil cooler. The bulkhead was also cut, but I don't have any photos of that process.
...but before we continue with the installation, I need to show you the excellent reproductions that Mark Allin (Rare Drive, Inc., previously "Precision Automotive Restorations) had custom made for me (Thanks Mark Allin!). Unfortunately, there is a sad story behind these parts and I will share it with you. The gentleman that Mark Allin used to fabricate the following two reproduction pieces, shortly after he finished and delivered them, was killed in a tragic motorcycle accident. I will never forget it, may he continue to rest in peace...
Below is a side-by-side comparison of his remarkable work. The original parts are the ones painted Black.
...below are close up photos after the parts arrived.
Old 10-08-2011, 12:11 PM
ajserrano's Avatar
Cont...
Old 10-08-2011, 12:16 PM
ajserrano's Avatar
Cont...
We first have to check these parts for proper fitment and probably make some adjustments along the way.
Old 10-08-2011, 04:11 PM
ajserrano's Avatar
Cont...
Front Oil Cooler Support Reinforcement
Because the 914-6 GT uses two rather large cut-outs at the front end between the torsion bars, it is important to try and restore some of the chassis rigidity that was potentially lost. There is one large opening required for the BEHR front oil cooler, and yet another at the bottom of the floor pan to allow the air flow to escape coming through the metal ducting of the oil cooler.
The following photo sequence is a bit detailed, but I don't want anyone to miss a step of what we're about to do in this section of the front end to reinforce it.
Let's take a look...
That's 1/8 inch plate being welded under the square reinforcement tubing. The thicker plate adds additional rigidity to this critical area.
Watch carefully what will take place next, a "David Copperfield" magic act!
Old 10-08-2011, 05:12 PM
ajserrano's Avatar
Cont...
See this plate? Look at how Mark grafts it back in place, as if it was never removed.
Here is the beginning of the grafting process...
Old 10-08-2011, 05:19 PM
ajserrano's Avatar
Cont...
After the piece is seam welded, Mark grinds away any excess metal...
Did you see that?
The following photo shows both plates masterfully grafted back in place. By now, I think you understand why I feel so fortunate to have a guy like Mark Spraker working on my car.
IMHO, the quality of fabrication and workmanship in this GT project is simply second to none...
Old 10-08-2011, 05:22 PM
ajserrano's Avatar
Cont...
This photo makes it easier to understand why we went through all this much trouble.
Additionally, once the front oil cooler bottom support is welded in place, it really makes the front end of this 914 very, very solid.
SIMPLY BEAUTIFUL!!! I LIKE!!!!
Old 10-08-2011, 05:25 PM
ajserrano's Avatar
914-6 GT Front Oil Cooler Protective Screen - Reproduction
I would like to also show you the reproduction photos of the 914-6 GT Front Oil Cooler Protective Screen that we fabricated. I actually have all these factory original (NOS) 914-6 GT parts so the reproduction was not actually made for me, but rather, for Sean Colon. I'm sure you will be as impressed with the results as Sean and I were.
BTW, in case you're wondering, we're not fabricating any more screens and the tooling is unfortunately no longer available. It was water damaged in my garage and I had to discard it.
Old 10-08-2011, 08:12 PM
ajserrano's Avatar
Cont...
Old 10-08-2011, 08:16 PM
ajserrano's Avatar
Cont...
Old 10-08-2011, 08:20 PM
ajserrano's Avatar
Cont...
Old 10-08-2011, 08:23 PM
Max Sluiter
Flieger's Avatar
I just can't believe how many NOS and real factory prototype (906-917) racing parts you can find. Especially the ones made from Magnesium that want to return to the earth from which they came. Are you using the 917/30 oil cooler?
911S
1971 chassis, 2.7RS spec MFI engine, suspension mods, lightened
http://www.flickr.com/photos/max_911_fahrer/
Old 10-08-2011, 08:25 PM
ajserrano's Avatar
Cont...
Old 10-08-2011, 08:26 PM
