Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 914 & 914-6 Technical Forum
Radmacdaddy (guest)
Guest
Posts: n/a
The last question needs to be answered. You don't discuss hydraulic lifters!!! I'm stuck. Tom wilsons book says two full turns after screw is seated on the valve. Any thoughts anyone?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: 914 Valve Adjustment Made Easy
Old 10-09-2011, 09:37 PM
gtc gtc is offline
abides.
gtc's Avatar
Wow, that answers a number of questions that I've always had regarding hydraulic lifters. Thanks for sharing!
Graham
1984 Carrera Targa
Old 10-10-2011, 03:39 PM
Send a message via AIM to jackmech
Yup the Ratwell page is the best resouce out there. Make sure that the lifters are fully pumped up before setting the adjustment. With a piston at TDC, you can't compress a pumped up lifter at all. If there is any squish, you need to keep trying to pump it up.
I had a hydraulic VW bug in the shop awhile ago and had to set all the valves with a small gap, drive with 'clacky' valves around the block, then adjust the lifters that had pumped up and keep repeating 4-5 times before all the valves were pumped and adjusted. After that they stayed pumped up and ran great.
Old 10-11-2011, 08:43 PM
