david.avery's Avatar
Question What kind of oil pressure sender is this?
Hey all
I have a VDO oil pressure sender mounted on what appears to be a brass fitting. It has the WK and G posts, with black plastic/brass thumbwheels. It is round...
Is this the stocker,or perhaps a VDO sender someone added on. I'd like to use a small VDO oil pressure gauge, and I was hoping it would be compatible with this sender.
Anyone know what this is, and whether I can use the standard VDO 80psi gauge for this?
Thanks in advance!
Old 04-02-2002, 08:11 PM
I have been told that the sender with two poles is for a gauge and the warning light in the dash. One pole is for the gauge and the other pole is for the light, And yes it is a VDO unit.
Old 04-03-2002, 07:51 AM
