please...i need some help fast....a 914 1974 2.0....i'm putting the rocker arms back on....where exactly does the bent wire go?...the book says to put it ontop of the head studs and on top of the push rods...???..if you put the bent wire on top of the studs then it will get pinched between the rocker arms and the heads???...does it go under the rocker arms to hold up the push rods???.....do i put it on after i put the rocker arms on?...please give some help in detail.....thank you to everyone that helps!!!!
thanks..john c.
john c. |
ok john here is my best shot at a description. The wire is used to add tension to the push rod tubes . It does this by actually looping beneth each push rod location and touching the bottom lip of the tube. It is held in place by the rocker are stand blocks an a slight indentation on each side of the head. The wire soes have a left and right end. If the rockers are installed properly then the slot will face down. With the rockers installed you can simply line up the steps in the wire with the push rod tube locations and the slots in the rocker arm stand blocks. The wire will snake a path from left to right below the rocker arms. Slide the steps into the push rod tube bores allowing the wire to rest on the bottom lip of teh tube avoiding contact with the push rod. Force, under tension, the upper steps in the wire into the slots in the rocker stand and allow the ends to rest in the head. hope this helps...I will look for a decent picture to help...scott
Scott 1982 911 SC 1962 sunroof bug 1991 WE Vanagon CARAT WRX conversion |
I was told from the shop, "FAT PERFORMANCE" that did my head work that this wire was no longer required. The wire, as I understand it, is to retain the push rod tubes in thier proper place. I hope they were right! I would appreciate any other comment you fine folks have on this topic??
Jim 71 914/4 to /6 73 914 restro 66 912 in pieces |
john911sc,
Scott is correct about the wires. They maintain slight tension on the push rod tubes so they stay in alignment with the cups on the push rods. With standard rockers and push-rods the wire is necessary. Haynes or CLymer manual should have picks showing the correct orientation, but Scotts description is accurate. Good Luck,
Gerard 74-914 White - Soon to be a custom 3.2L Six 87-924S 2.5L Artic White - SOLD 74-914 2.0L Ravenna Green - SOLD
If the tubes are installed by the book, with only oil on them, the wire is needed.
We toss the wire and use loctite 518 or permatex teflon pipe thread sealant on the tubes, they never leak, or move.
Jake Raby Raby's Aircooled Technology http://www.aircooledtechnology.com |
