-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   vw Bus to 914 1.7 engine transfer (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/65188-vw-bus-914-1-7-engine-transfer.html)
Ryan Holsopple 04-09-2002 05:39 AM
I'm putting a VW Bus 1.7 engine in a 914. Does anyone have thoughts about converting
the oil check dipstick to the rear of the engine. Is it best to drill a new dipstick hole in the enfine block
or is there a modification that can be made to the existing dipstick that will make it accessible
in the front of the 914 engine compartment? Naturally, I don't want to have to drill a new hole.
Any thoughts or suggestions?
jmcleod 04-11-2002 05:40 AM
get a dipstick and dipstick tube for a 914 engine and replace the ones for the bus engine with the ones for the 914 engine. no new holes. if i remember my vanagon engine, the dipstick tube mounted in the same place as a 914 engine but curled over the top of the engine to the access door and was "bolted" to the fan housing.
