-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Question About Dwell Meter Use (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/65800-question-about-dwell-meter-use.html)
ddustan 04-16-2002 06:06 AM
I have been coddled with electronic ignition for many years so have a question about using my old dwell meter.... Other than the obvious two battery leads, where does the coil lead go?
:confused:
HMeeder 04-16-2002 09:06 AM
Uh... not quite clear here.
By 'coil lead' do you mean a clip that looks like it would slip over a spark plug wire?
Most multimeters do several things besides measure the dwell and that 3rd lead slips over the #1 plug wire.
The red lead attaches to the negative post on the coil (it is labeled with a "1" and the condensor wire from the dizzy runs to it.)
The black lead is grounded anywhere you want on the frame/motor.
ddustan 04-17-2002 05:36 AM
Hmmm... I guess technology has changed in the last 25 years since I bought this thing! ;) This has two battery cables and a yellow lead with an alligator clip. Maybe what I really need to do is go get a new meter. I think its time!
The negative post is what I need I think. Like I say, it's been a long time!! :)
DSPTurtle 04-17-2002 06:53 AM
Negative post on the coil is what I use...
