-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   How do I test my Temp gauge? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/667843-how-do-i-test-my-temp-gauge.html)
Rods914 03-25-2012 10:00 PM
Is there a way to test a 1973 center console temp gauge with a OHM meter? I looked in the tech forums here but could not find any specs. This is a gauge from my stash of parts and I would like to eventually sell it. Any help would be appreciated. Thanks Rod Bell
Dave at Pelican Parts 03-26-2012 09:05 AM
You can test it by hooking it up to power, and ground, and to a resistor to ground. The sender (hooks up to the "G" terminal) is actually a thermistor, a resistor whose resistance changes with temperature. So you could use a potentiometer to simulate that. I don't remember the resistance range for the stock sender, though. You should see a change in reading going from just a few ohms of resistance to several hundred or several thousand ohms.
--DD
Rods914 03-26-2012 11:19 AM
Temp gauge test
Thanks Dave!! :) I will run that test and see what happens. Thanks also for maintaining a Great web site I always learn a lot when I spend time here!! Rod
