Unhappy throttle body screw adjustment
on my 1974 914 2.0....there is a screw on the side of the throttle body for the fuel injection....on the throttle body there is no outlet for a tube going to the distributor...so what does the screw adjust?...and what spec do you adjust it to?...thanks..john c.
john c.
Old 05-22-2002, 09:54 AM
bowlsby's Avatar
Its for adjusting bypass air around the closed throttle plate at idle conditions. Its called the "idle air adjustment screw"...
Old 05-22-2002, 12:37 PM
