Harpo's Avatar
OE Muffler hanger
I'm in the process of converting my 1.8 in to a 2056. Do I now need a 2.0 muffler hanger?
Old 04-29-2012, 10:28 AM
It has nothing to do with the displacement change, you use the muffler hanger that matches the heat exchangers and muffler.
Old 04-29-2012, 10:37 AM
ditto above.
if you run a 2.0 set of heat exchanger, then you need a 2.0 muffler and 2.0 hanger
if you run a 1.7/1.8 set of heat exchangers, then you need a 1.7 muffler and hanger.
and there is a bit of horse power to be gained to get rid of the late 75 style reverse loop exhaust system...
make sure you use the early 1.7 or early 2.0 style systems.
914/6 2.0S with twin plug
all metal body panels
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 04-29-2012, 11:27 AM
