-   Porsche 914 & 914-6 Technical Forum (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/)
-   -   Outer Fuzzy install? (http://forums.pelicanparts.com/porsche-914-914-6-technical-forum/67493-outer-fuzzy-install.html)
RustyWa 05-03-2002 09:35 PM
Putting my car back together after the paint job. My old outer fuzzy strips on the doors are toast, so new ones are on the way. All the door inards and outards are still in pieces.
So, my question. Can I just attach the fuzzy strip rail to the door, then put in the glass (the roll-up), then slide the fuzzy strip in to place? The quarter window and channel is not installed yet and it looks like there is enough room if the door is open.
I just remember removing the window glass was a real pain while the old fuzzy strip was installed. The welded on nut on the bottom of the window did not like getting by the old fuzzy. I kind of had to spread the top of the inner door with my fingers to get it by. Maybe I was doing it wrong..
