Harpo's Avatar
Dellorato carbs fittings
Does anyone know what the thread size is on the banjo bolt for the fuel inlet? I would like to use AN fittings but I'm having a hard time finding fittings. The Aeroquip FCM 1068 looks good but the banjo bolt is M12-1.5 threads. I'm guessing but the dells might be M12-1.25
DAvid
Old 05-06-2012, 09:53 AM
mike95125's Avatar
M12 x 1.5 and 1.25 are common. Best to get a bolt and see if it fits
AKA: Dr Evil on the 914World forum, need your tranny rebuilt, or want a "How to rebuild your transmission DVD" set? PM me.
-74 914 with 74 2.7 CIS
-74 VW Bus with modified 3.1 corvair engine and 3.0 CIS fuel injection system.
-74 BMW R90
Old 05-06-2012, 04:16 PM
Harpo's Avatar
M12-1.25 threads
I took the banjo bolt to work and checked with a gauge. Earls is the only one that makes a double banjo fitting.
Old 05-07-2012, 06:12 PM
Dave,
here are a few sources for Dellorto parts.
The older carbs have a 7mm banjo fitting.
AN Special Fuel Adapters | ANplumbing.com
Dellorto DHLA Parts Shop
CB Performance - Online Catalog
hope it helps
Dave
Old 05-11-2012, 07:01 PM
