Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
924 engine swap?
I can't find any info on this, and that may be my answer, but would a Porsche 924S 2.5l engine mate up with a stock 901 tranny with side shift?
Would it be a direct swap, or an expensive custom job?
Old 05-22-2012, 12:17 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
Expensive custom job.
I believe the length of the engine is a factor as well; it might require moving part of the firewall to even get it to fit in the engine bay. I know this is needed with 928 swaps, and I think I remember reading that the 944 and 924 motors offered similar fitment problems.
--DD
Old 05-23-2012, 06:36 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
Darn it! Well I guess I'll keep looking for options, and keep the 4.3l on the table.
Old 05-23-2012, 09:06 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
kellzey's Avatar
Look into a Subaru engine conversion!
Karl Ellzey
Orlando, FL
My 914-6 GT Project
Old 05-23-2012, 03:20 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
Licensed User
Shuie's Avatar
Someone needs to do a 4.2l audi V8 swap. The weight and dimensions of the ABZ engine seem perfect for a 914 and the motor bolts right up to one of the cheap Audi A4 TDI gearboxes that can easily handle 400hp+ and gobs of torque. Above average fabrication skills would obviously be needed to make it all work, which is why I daydream about it instead of doing it myself, but it would be a great conversion.
Old 05-23-2012, 03:40 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
What are the advantages of a subaru engine over, say a chevy 4.3l?
I haven't looked into a subaru, but do their flat engines need modifications to the 914 mounts?
Old 05-24-2012, 06:22 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Administrator
They do not bolt up any better than the SBC does. The advantages are that the flat layout keeps the CG lower, most of the Scooby motors are fairly light, and they make noises that are in character with the original motors.
--DD
Old 05-24-2012, 08:40 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
Resident Electrician
kg6dxn's Avatar
I'm doing an Audi 1.8t swap right now. Should have it running by next Spring. I have a FWD 5 speed to match but I may swap to a Boxster tranny. It's a direct bolt on AND the shifting system is off the shelf bolt on. The Boxster CV flange is 100mm so only the axle length will have to be changed on mine.
Current Project: 73 914, 1.8t, ~300hp, 930 Brakes, Roll Cage
Past Projects:
69 911, converted to C2 wide body cabriolet 3.2L
72 914, Ford 5.0L V8 EFI
Old 05-26-2012, 07:40 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
Chris Scott's Avatar
The boxster 5speed is the audi 012 front wheel drive trans.
Old 05-28-2012, 09:02 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
Wingnut86
wingnut86's Avatar
Cool
That' a bunch of hardware needing direct access to get to in a 914. Are you modifying and expanding the bump behind the 914 seats?
1976 914 2.0/Roller - Jack-stands and Drip-pans
1970 914 1.7 - Tarped and Parked
1972 914 1.7/Roller parts donor for the Twisted-Sisters above
..."...what we've got here, is Failure to Communicate..."
Old 05-29-2012, 05:05 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
1.8t swap is a homerun! IMO, it is THE swap for this car. Good luck - hope it comes together quickly. It's gonna be FAST...
Old 05-31-2012, 07:12 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #11 (permalink)
kg6dxn's Avatar
It's almost the same. Different axle flanges, different shift linkage, different differential.
Past Projects:
Old 05-31-2012, 07:31 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #12 (permalink)
kg6dxn's Avatar
I already have a hole in the hump from the old track days. The engine should fit without firewall mods. May have to trim the trunk lip a little. Got to get it in there first. Al at Parts Heaven asked me to bring it to their swap meet this weekend. So I will start major work soon. I will be selling a rebuilt 901 with an H gear, setup with a cable shift. PM me with an offer if you want it.
The timing belt and water pump will be changed before the swap. Should be good for 60k miles. I am fabricating a cradle to house the engine and tranny. 4 bolts, CV's, hoses and shifter and the engine combo will drop out. No more difficult than pulling a T4 motor. Just a little messy with all the coolant.
Past Projects:
Old 05-31-2012, 07:43 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #13 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
