speedo cable o-ring replacement
I traced the leak in my trany to the speedo cable, acording to an illistration in the haynes manual, it looks like this cable and its gear is held in by a lock bolt, is this the only bolt I have to remove to access the o-ring? for a replacement will a "kragen" type place have this o-ring?
easy problem solved, end this thread.... thanks
