glass rubbers
does any body have a picture of the rubber that goes up the edge of the door post that the glass shuts on to when closed .unless my window is down a bit it won,t go past the rubber and shut properly thanks brian
Old 09-17-2012, 02:38 PM
John Rogers's Avatar
Sounds like you need to adjust the window glass a bit? It can be adjusted up/down, in/out at the top and angular so the top sits even with the targa top rubber. There are many posts here on how to do the adjustments if you search around.
Old 09-17-2012, 03:30 PM
