sleepdoc's Avatar
901 transmission
Hi All
Can I replace the 901 output flange seals with the
tranny in the car?
Once the axels are off what holds the output flanges in the tranny?
Old 06-04-2002, 09:46 PM
roadtrp204's Avatar
Yes, they can be replaced in the car. A special long bolt and washer hold the flange to the differential.
Chris
75 914 2.0L
Old 06-04-2002, 10:34 PM
Jim Smolka's Avatar
To minimize the oil loss, it is best to have only the rear jacked up, prefferably one side at a time. If you are replacing the seals, clean the old seal and use it as a special tool to help tap in the new seal.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 06-05-2002, 03:48 AM
Unregistered
sammyg2's Avatar
Make sure you torque the stretch bolt to the right torque, no guessing allowed here.
Old 06-06-2002, 02:35 PM
sleepdoc's Avatar
Thanks Everyone,
Since putting sweepco in my box I am seeing a modest leak on the drivers side output flange. Possibly it was there before but it is easy to see in blue. Also the box was more or less topped up when I went to change the lube oil. I will try changing the seal and see how it goes.
best Mark
Old 06-06-2002, 10:36 PM
